  3. IFC Import Settings for macOS Ventura
3 Posts 2 Posters 633 Views
  • O Offline
    O Offline
    oliverVienna
    Hello Forum,
    If I import an ifc in solibri on my macbook air, the ifc is decoded incorrect. Which IFC Import Settings do you recommend for macOS Ventura?
    Thank you very much!
    Best wishes,
    Oliver
      @oliverVienna It is possible that your IFC uses some non-standard character encodings. You can try to change the character set used in IFC reading in File/Settings/IFC Import Settings. Unfortunately, I don’t know what would be the recommended character set. If the IFC file has been created in a Windows computer, you can try to use the windows-1252 (Europa) character set.
      • O Offline
        O Offline
        oliverVienna
        Hello @Pasi-Paasiala,
        thank you very much for your suggestion. It works perfectly:)
        Best wishes,
        Oliver
