  3. unused classifications
3 Posts 2 Posters 559 Views
  • O Offline
    O Offline
    oliverVienna
    Hi guys,
    I have a simple question: is there a disadvantage to loading many classifications into a Solibri file, even if I don’t use them in my ruleset?
    The reason for my question is:
    My office has several rule sets for different use cases. Each rule set has its own set of classifications. To simplify our workflow, we would like to load all classifications for each use case.
    Thank you for reading my question.
    With kind regards,
    Oliver
      @oliverVienna In general classifications don’t require a lot of memory. Sometimes classification calculation can take time depending on the information that the classifications use. If you’re using mainly textual information coming from IFC, then the calculation normally doesn’t take a lot of time.
      • O Offline
        O Offline
        oliverVienna
        Hi @Pasi-Paasiala, that’s good news. It makes it a bit simpler for us. Thank you very much! Best wishes, Oliver
