Rulesets include multiple classifications
Hi!
Does anyone else have an issue with multiple classifications to include components?
For example with the ruleset : general intersection rule.When I try to add components with classifications, it only works if I use a single include with a classification and exclude with a classifications. However, if I use multiple includes with classifications, it doesn’t report any issues. But in both cases the components are the same …
Thanks
Similar here
When I create multiple classifications e.g. for general intersection rule - the outcome doesn’t make sense. When I configure the rule filters in the same way but without classifications, it works. (Btw - didn’t checked that since the last update - I adapted my workaround…)Looking forward seeing any solution
@Gianni @MEA The filtering creates an “AND” operation between two rows that have the same component. If you have, for example, two rows with “Any” component that their requirements don’t overlap, you get nothing as result.
What kind filter you want to create?
If you want to create a filter that matches several classification names, use the “One Of” operator and list all the classification names you want to match there.
