  3. Cant run autorun
Cant run autorun
4 Posts 2 Posters 1.2k Views
    MadsHA
    Hey Everyone,
    I have been trying to setup the solibri autorun, following the example here: https://solibri.github.io/Developer-Platform/9.10.8/autorun-examples.html but when i run it, solibri starts to load and then closes. the log file gives me the following error:
    2023-05-10 08:20:34.629+0200 ERROR c.s.s.p.b.actions.BatchAction - Failed to create BatchRun
    org.jdom2.input.JDOMParseException: Error on line 1 of document file:XXXX/XXX%20Solibri.xml: Invalid byte 2 of 3-byte UTF-8 sequence.
    (deleted the filepath)
    After the fail error it comes up with a longer list of details
    This is how the first lines of the document is writen:
    <!-- Standad tekst skal ikke ændres -->
    <?xml version=“1.0” encoding=“ISO-8859-1”?>
    <batch name=“Simple Batch” default=“root”>
    <target name=“root”>
    <!-- Solibri modellen åbnes – "Sti til Solibri modellen Skal TILPASSES " -->
    Any help will be much appreciated 🙂
      MadsHA
      I edited the start to look like this:
      <!-- This is the starting task -->
      <openmodel
      and it works now if anyone ends up having similar issue
        replied to MadsHA on last edited by
        @MadsHA
        Thanks for this. I reported this to our database. This might be problem in encoding set for the XML reader.
          @MadsHA
          I could not reprodude this.
          Could you send a small zipped sample autorun file that is problematic.
