  3. Confusion about Topic ID’s
2 Posts 2 Posters 414 Views
  • Paul DeckersP Offline
    Paul Deckers
    Every time you create a presentation using from checking results, Solibri makes use of the same slide but them gives them different topic ID’s. Does this make sense?
    Any update to one presentation results in an update in the other as they are using the same slide. Yet still they are different issues?
    This has resulted in issues being duplicated within a BIMcollab project and will be so for other systems as well I assume.
      andreas_baumann
      Were you ever able to resolve the issue? A client of ours has the same problem and we’re not sure whats causing it. Now we have a ton of duplicates in our Database. Did the problem go away by itself and do you know at what Version it stopped?
