  3. Results custom Hierarchy sorting error
6 Posts 4 Posters 1.8k Views
    MadsHA
    Hi everyone
    I was trying to use the custom Hierarchy with the 09 rule that checks for allowed property from my classification
    I am checking if the right pipe insulation is applied and have 3 classification groups, approved, not approved and no insulation.
    But since there can be a lot of pipes with wrong pipe insulation i wanted the checkers to be able to sort with systems, but since the error is connected to the pipes in general it seems it cant sort it further
    The first sort is the classifcation, and the the systems, but when i open the first system it contains all the pipes with wrong insulation and not just the system
    as you can see the scroll wheel extends by a lot, and it takes all the pipes with the classification.
    If anyone have a solution to this it is much appreciated
    /Mads
    MattiM 2 Replies Last reply
      replied to MadsHA on last edited by
      @MadsHA
      thanks for reporting this
        replied to MadsHA on last edited by Matti
        @MadsHA
        Currently Solibri is listing all components of the issue regardless of the parent level.
        The hierachy applies only to issue level. We could have a have an option to show only the components that matches the parent nodes.
        M 1 Reply Last reply
        3
          MadsHA
          @Matti-Kannala That would be a nice feature, until that i assume the best solution is to make extra classification categories based on the system (in this case)
          • E Offline
            E Offline
            Ehillerby
            Has this been introduced? @MadsHA @Matti ? - Would be great to see this as a feature as for large projects it seems unfeasible to create specific classifications at a specific item level when there could be thousands.
            • MattKnowlesM Offline
              MattKnowles
              i Have this issue quite a lot. We like to set our Hierarchy by short name but we constantly get other items included. If we could lock it to the main parent check this would be great
