  3. Export all PropertySets with all Properties
6 Posts 4 Posters 1.7k Views
    alex4omnicon
    Is there a way in Solibri to export all PropertySets and Properties sorted by IfcClasses? I would like to give my colleagues an overview of the existing properties.
    If not, is there an alternative with other tools?
    best regards
    Alex
      Not out of the box, but you could do this with the API. Not sure if there is a non-coding alternative out there in other tools to get you that kind of/all information.
        alex4omnicon
        Do you have some codesnippets? I’m working with the rules api.
          Not really but afaik there must be an example for the propertystream somewhere here. You could iterate trough all psets and properties and get the values by component as a custominfo string and use it in an ITO.
          • E Offline
            E Offline
            elia
            Hi all,
            Did anybody come up with a solution and is so kind to share? Many thanks 🙂
            • john.lippJ Offline
              john.lippJ Offline
              john.lipp
              wrote on last edited by john.lipp
              Hi @elia
              Here is a JavaScripted ITO that exports all properties of each IFC class, with each property separated by a semicolon.
              All Properties.ito
              Note that JavaScripted ITOs in Solibri have certain limitations, such as the lack of support for enhanced for-each loops and stream operations. As a result, this script relies on iterators and while loops.
              However, if you’re developing your own Solibri API extensions using Java, these limitations do not apply. This example can serve as a useful reference for accessing PropertySets and their associated Properties from Components.
              importClass(java.util.HashSet);
              importClass(java.lang.StringBuilder);
              function getValue(row, components) {
                var componentIterator = components.iterator();
                var psetSet = new HashSet();
                while (componentIterator.hasNext()) {
                  var component = componentIterator.next();
                  var propertySets = component.getPropertySets();
                  var propertySetIterator = propertySets.iterator();
                  while (propertySetIterator.hasNext()) {
                    var propertySet = propertySetIterator.next();
                    var propertySetName = propertySet.getName();
                    var properties = propertySet.getProperties();
                    var propertyIterator = properties.iterator();
                    while (propertyIterator.hasNext()) {
                      var property = propertyIterator.next();
                      var propertyName = property.getName();
                      psetSet.add(propertySetName + "." + propertyName);
                var result = new StringBuilder();
                var psetIterator = psetSet.iterator();
                while (psetIterator.hasNext()) {
                  result.append(psetIterator.next()).append(";");
                return result.toString().trim();
