  3. Test for distance between Opening by MEP and slab, advanced
1 Posts 1 Posters 342 Views
  • O Offline
    O Offline
    oliverVienna
    Dear Solibrians,
    does anyone have a suggestion on how to check the distances between the openings supplied by MEP and the slabs.
    The rule should apply if the distance is smaller than a defined threshold (no distance between opening and slab) and is greater than a defined threshold value.
    I have attached a screenshot showing the result I am hoping for.
    I have tried the following:
    23 components must touch other components as a gatekeeper rule:
    Any opening closer than a defined threshold to a slab is passed to the next rule. (The opening is probably too close to the slab)
    222 Component distance:
    Checks if the opening is not actually meant to touch the slab. The distance should be smaller than 1 cm.
    This does not work because only the openings are passed on to the rule inside, but not the slabs.
    Thank you for reading my question.
    Yours sincerely,
    Oliver
