  3. Cant select points in PDF
6 Posts 4 Posters 1.4k Views
  • J Online
    J Online
    Jim.persson
    Hi
    I´m having an issue when trying to insert a PDF drawing in solibri.
    I can´t pick dimension point on the PDF only the 3d model.
    Any idea what could be causing this?
      At least, if you turn on Dimensioning, you can pick lines.
      • J Online
        J Online
        Jim.persson
        wrote on last edited by Jim.persson
        Dosen´t work for me at all. I can pick dimensions in the model but not the PDF. is it somthing im missing?
        • J Online
          J Online
          Jim.persson
          Can pick some strange lines in the PDF
          • H Offline
            H Offline
            HarriSalminen
            Hi jim,
            Are you sure that your PDF-file is vector based? You can’t pick anything from rasterized picture in PDF
              solmac
              Hi! We noticed that there could sometimes be fills in the PDF. They are blocking lines below the fills.
