  3. Classification Names vs Colors
5 Posts 4 Posters 706 Views
    SCHV
    I’ve created a Classification according to the project’s WBS. It’s working well, but the coloring of the elements isn’t working according to the Classification Names color, defined in the settings - see the pic below.
    A few classifications need to load the rules for coloring according to the setup. Could someone help how to fix this issue?
    Thanks so far.
    • Harmen JorritsmaH Offline
      Harmen Jorritsma
      @SCHV
      Look if the classification name and the name in the setting for collering are exactly the same. Maybe there is a space(bar) behind the line in the settings.
      Harmen Jorritsma
        replied to Harmen Jorritsma on last edited by
        @Harmen-Jorritsma said in Classification Names vs Colors:
        Afaik Blank spaces get automatically truncated in classifications at the end but in general this is a good tip. Sometimes also closing and opening classifications can help if they refuse to update. They can be a bit stubborn. And check out if you are running the latest version.
          I have seen this happening earlier also.
          Please contact support. If you are able to send the model there they might be able solve the problem.
          My quesses:
          • whitespaces
          • decomposed components (consisting of multiple parts)
            SCHV
            Thanks, @Harmen-Jorritsma and @JSN, for your valuable tips. I’ve used Excel and cleaned up unnecessary spaces, and it worked.
            Thanks also to @Matti-Kannala for your offer of support.
            • jakub.rusinJ jakub.rusin has marked this topic as solved on
            • jakub.rusinJ jakub.rusin unlocked this topic on
