  3. Wrong visualization of results
6 Posts 4 Posters 1.4k Views
    Could not find the existing topic on that so once more …
    We get a warning triangle when rules are collapsed …
    although everything is fine (passed or at least accepted)
    Most likely due to the gatekeepers.
    • paola bronzoP Offline
      paola bronzo
      I have also noticed strange behaviors of the gatekeeper too.
      Often the symbol next to the “parent rule” does not correspond to the results of the sub-rules within it.
      • Alex.JA Offline
        Alex.JA Offline
        Alex.J
        Same here
        • E Offline
          E Offline
          esme
          wrote on last edited by esme
          I think that happens because when you use gatekeeper rules you also check something in your “parent rule” and then you choose which components of the result will be take for the next rule. So there are generated problems in the “parent rule” that aren’t real problems and I assume that’s why the triangle is shown.
          You can also see it in the result summary. The “parent rule” has many more issues than the sub-rules.
            replied to esme on last edited by
            @esme Indeed, that’s also my guess. But I don’t think that this should be a desired behavior though.
              UI is different now, but the UX is still irritating …
              Collapsed
              Expanded
