  3. Could not initialize 3D GL_FRAMEBUFFER_INCOMPLETE_MISSING_ATTACHMENT_EXT
3 Posts 2 Posters 822 Views
    andreas_baumann
    wrote on last edited by andreas_baumann
    Solibri won’t show any 3D-Models. Everything works but the 3D Pane.
    In the logfiles I can see, that an IllegalStateException was thrown.
    2024-04-30 16:24:56.042+0200 [main] INFO  com.solibri.sae.smp.Licensing - Starting Solibri ANYWHERE.
    2024-04-30 16:24:58.065+0200 [main] INFO  c.s.s.p.java3dplugin.Java3dPlugin - Initialized 3D (OpenGL)
    2024-04-30 16:24:58.577+0200 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Vendor: ATI Technologies Inc.
    2024-04-30 16:24:58.577+0200 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Renderer: AMD Radeon HD 8450
    2024-04-30 16:24:58.577+0200 [Render Loop] INFO  c.s.s.plugins.java3dplugin.ardor3d.g - Display Version: 4.5.13399 Compatibility Profile Context 15.201.1151.1008
    2024-04-30 16:24:58.583+0200 [Render Loop] ERROR c.s.s.plugins.java3dplugin.ardor3d.g - Could not initialize 3D
    java.lang.IllegalStateException: FrameBuffer: 2, has caused a GL_FRAMEBUFFER_INCOMPLETE_MISSING_ATTACHMENT_EXT exception
    	at com.ardor3d.renderer.lwjgl.LwjglTextureRenderer.checkFBOComplete(LwjglTextureRenderer.java:388)
    	at com.solibri.saf.plugins.java3dplugin.ardor3d.g.a(Unknown Source)
    	at com.solibri.saf.plugins.java3dplugin.ardor3d.g.n(Unknown Source)
    	at com.solibri.saf.plugins.java3dplugin.ardor3d.g.o(Unknown Source)
    	at java.base/java.lang.Thread.run(Thread.java:833)
    I’m not aware of any changes to my Setup. Anyone knows, how to resolve this?
      Looks like you run Solibri with AMD Radeon HD 8450.
      If your laptop has another GPU try that, e.g. Intel GPU.
      A 1 Reply Last reply
        andreas_baumann
        @Matti-Kannala Yes that worked, thank you!
        I had to disable the other GPU though. I tried to force the iGPU through the Graphics Settings in Windows 10, but Solibri always uses the AMD Card if it’s not disabled. Do you by any chance know, which .exe I have to create the Graphics Settings rule for, so Solibri uses the internal GPU? I tried Solibri.exe, java.exe and javaw.exe.
