  3. About search field
About search field
3 Posts 2 Posters 731 Views
  • H Offline
    H Offline
    HieuVH-FPT
    Hi Solibrians
    I have a problem when using search field
    I have a GUID like 0YwA$cEwz7J9wGqk$Rytnj
    When I use search field, it doesn’t return any component.
    But I use filter instead, it returns 1 component.
    The exactly GUID of component is 0YwA$cEwz7J9wGqk$RYtnj
    May the search field search component that need to be equal each other while filter need to be equal but ignore case?
    Thanks
    • jakub.rusinJ Offline
      jakub.rusin Solibrians
      Hi @HieuVH !
      Here are some questions that can narrow down the issue a bit:
      What is that component?
      What IFC entity?
      Do you see it in 3D when filter finds it?
      What filter settings do you use (GUID Matches or GUID Contains)?
      • H Offline
        H Offline
        HieuVH-FPT
        Hi @jakub-rusin
        It can be any type of component and IFC entity.
        Yes, I see it in view 3D when filter finds it.
        Here is my filter setting:
