Error Saving and opening SMC
I have been testing the Fire stopping ruleset with one of our models. I am finding that the model almost never finishes to save and when I try to reopen reopen it I am getting the following dialog box with the error.
Any ideas?Thanks
Application build number: 9.13.8.22
Model is saved with build number: 9.13.8.22java.io.UTFDataFormatException
at java.base/java.io.ObjectInputStream$BlockDataInputStream.readUTFSpan(ObjectInputStream.java:3736)
at java.base/java.io.ObjectInputStream$BlockDataInputStream.readUTFBody(ObjectInputStream.java:3680)
at java.base/java.io.ObjectInputStream$BlockDataInputStream.readUTF(ObjectInputStream.java:3480)
at java.base/java.io.ObjectInputStream.readString(ObjectInputStream.java:2093)
at java.base/java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1715)
at java.base/java.io.ObjectInputStream$FieldValues.<init>(ObjectInputStream.java:2606)
at java.base/java.io.ObjectInputStream.readFields(ObjectInputStream.java:691)
at com.solibri.sae.redox.Issue.readObject(Unknown Source)
at jdk.internal.reflect.GeneratedMethodAccessor88.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at java.base/java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:1100)
at java.base/java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:2423)
at java.base/java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:2257)
at java.base/java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1733)
at java.base/java.io.ObjectInputStream.readObject(ObjectInputStream.java:509)
at java.base/java.io.ObjectInputStream.readObject(ObjectInputStream.java:467)
at java.base/java.util.HashMap.readObject(HashMap.java:1552)
at java.base/jdk.internal.reflect.GeneratedMethodAccessor80.invoke(Unknown Source)
at java.base/java.io.ObjectInputStream.defaultReadObject(ObjectInputStream.java:647)
at com.solibri.sae.greenox.Constraint.readObject(Unknown Source)
at jdk.internal.reflect.GeneratedMethodAccessor82.invoke(Unknown Source)
at java.base/java.io.ObjectInputStream.readArray(ObjectInputStream.java:2157)
at java.base/java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1721)
at java.base/java.util.Vector.readObject(Vector.java:1158)
at java.base/jdk.internal.reflect.GeneratedMethodAccessor18.invoke(Unknown Source)
at com.solibri.sae.redox.Property.readObject(Unknown Source)
at jdk.internal.reflect.GeneratedMethodAccessor38.invoke(Unknown Source)
at com.solibri.sae.redox.Model$ClassNode.readObject(Unknown Source)
at jdk.internal.reflect.GeneratedMethodAccessor63.invoke(Unknown Source)
at com.solibri.sae.redox.Model.readObject(Unknown Source)
at jdk.internal.reflect.GeneratedMethodAccessor97.invoke(Unknown Source)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at com.solibri.sae.redox.Model.b(Unknown Source)
at com.solibri.sae.redox.Model.openModel(Unknown Source)
at com.solibri.saf.plugins.modelhandling.actions.OpenModelAction.a(Unknown Source)
at com.solibri.saf.plugins.modelhandling.actions.OpenModelAction.openModel(Unknown Source)
at com.solibri.saf.plugins.modelhandling.actions.MultiModelOpenAction$b.construct(Unknown Source)
at com.solibri.sae.ui.ad.run(Unknown Source)
at java.base/java.lang.Thread.run(Thread.java:833) -
Is the original model an smc file or an ifc file? Is it possible for you to share the original model with Solibri customer support? This looks like one of the issues generated has invalid UTF text in the issue name. It could be due to the ifc model, in which case we can probably figure out what is going wrong and make sure the Solibri application can handle it.
@Cahit I have received the model and I am looking into the problem.
