  3. Check that every Floor is associated to one Space
4 Posts 4 Posters 824 Views
  • U Offline
    U Offline
    UCare95
    Good morning.
    Maybe it will be a trivial question but i’m new to the software, i’m trying to check that the finishing Floor is divided for every Space, to prevent a floor from being modeled as a single instance across multiple spaces, but i can’t find any solution, due to the fact that also when i select a Space in Solibri i don’t see any relation with any Floor.
    Do you have any advice on how to manage this aspect? Also because the next thing i’ll do will be to apply the same concepts for Ceilings too.
    Thank you in advance.
    • F Offline
      F Offline
      f.zanoni
      I’m interesting in this too
        Relations should be visible in the Info view as tab when you click a Space.
        Could you add some pictures. It would help to understand the problem.
          JulianJ
          In other software we used to clash detect ceilings and floors against walls. This would visually show where floors had been modelled incorrectly. You could try a similar rule in Solibri based on template 245 but try floors clashing with more than one space/room.
