  3. Modyfying rules & rulesets
7 Posts 3 Posters 1.5k Views
    Protiimi_Johanna
    I’m quite new to Solibri. I’ve been watching the tutorials about rulesets, but still finding it quite hard to achieve the results that I want. One issue that I have, is that I have a model of multi-storey building, but I would like to check only one storey. What is the easiest way to achieve this? In general, where can I find information of the sample rules, what they can be used for?
    jakub.rusinJ 1 Reply Last reply
      Hello! You have probably already visited help, but in case not, there are some relevant articles here:
      https://help.solibri.com/hc/en-us/categories/1500000245661-Solibri-Rules
      P 1 Reply Last reply
      • jakub.rusinJ Offline
        jakub.rusin Solibrians
        replied to Protiimi_Johanna on last edited by jakub.rusin
        Hi @Protiimi_Johanna
        @Protiimi_Johanna said in Modyfying rules & rulesets:
        Most rules have Filter in Parameters View.
        Filter can be powerful tool that can help with checking specific components.
        As an example, Rule #226 - Free Are in Front of Components:
        In the Parameters of this Rule a Filter can be set up, so that it will only check components from specified floor:
        More on Filtering here:
        https://help.solibri.com/hc/en-us/articles/12771718136343-Filtering-Components
          Protiimi_Johanna
          @tonigyllenberg
          I’ve already read some articles, but it seems this one has the answers to many of my questions:
          https://help.solibri.com/hc/en-us/articles/1500006958582-How-to-Choose-the-Appropriate-Rule
            Protiimi_Johanna
            replied to jakub.rusin on last edited by
            @jakub-rusin
            OK! This filtering seems to be a really good tool! I’m wondering, if I want to check several rulesets, is it better to filter all of them individually or is there an easy way to create a gatekeeper rule that filters all of them? Thinking ahead, what happens when I want to change / expand the checked portion of the model? What happens to the old issues if I change the rulesets?
              @Protiimi_Johanna
              Yes, Gatekeeper Rules are the way to go if you want scalability.
              Continuing with the 2nd floor example, Gatekeeper Rule would be #230 Property Rule Template with Component Filters.
              You set it up in Ruleset Manager.
              Please find more thorough information here:
              https://help.solibri.com/hc/en-us/articles/4415773412247-Using-Gatekeeper-Rules-to-Filter-Components-into-Sub-Rules
              Beside many Help articles on http://help.solibri.com/ you can also check our eLearning platform here:
              https://www.solibri.com/solibri-elearn
              and Solibri Academic Program: https://society.solibri.com/category/34/solibri-academic-program
              When you change the checked portion of the model or the rulesets, you should re-run the checks. Old issues from previous checks may become outdated or disconnected, so always review and update issues after making such changes.
              And more articles:
              https://help.solibri.com/hc/en-us/articles/4407634031255-Part-4-Rule-Refinement-1-My-First-Ruleset
                Protiimi_Johanna
                @jakub-rusin This works perfectly, thank you!
                • jakub.rusinJ jakub.rusin has marked this topic as solved on
                • jakub.rusinJ jakub.rusin unlocked this topic on
