  3. Coordinate stamp visibility in Solibri 24.9
5 Posts 3 Posters 1.1k Views
    Jonna Lehto
    Why is the coordinate stamp located lower than the cutting plane? I use Solibri 24.9.0.38.
      Coordinate stamp is not placed on the section plane, because otherwise it would be hard place stamps behind the plane. What is your use case?
        Jonna Lehto
        I use a stamp to show the area that needs to be repaired. I think this is a bug.
        • BvanDalsumB Offline
          BvanDalsumB Offline
          BvanDalsum
          @Jonna-Lehto , You can unhide the section bij pressing T. then if you make a mark-up it doesn’t snap the sectioning
            Jonna Lehto
            The stamp should snap to the surface of the cut. Not behind it. Now it’s hidden.
