  3. Read Error [Solved]
Read Error [Solved]
3 Posts 2 Posters 1.5k Views
    b.huijskes
    wrote on last edited by b.huijskes
    Hi!
    I’ve started experiencing problems when opening models from networks other than the company network when trying to connect to ACC through the integration.
    When I work at our office, the error magically disappears and everything works like it should.
    Before opening the model, I am able to connect to ACC and navigate to the right folder / model (implying that the connection itself works, else I would not show me the ACC folder structure).
    Only upon selecting the model and trying to open it, will it displays this error. I am running the latest Solibri version (25.3.1.59) on a Windows 11 laptop.
    Reading through the error code, I can’t really pin down what the cause might be. Is anyone having similar issues, or might know in what direction the solution might be?
    Application build number: 25.3.1.59
    Model is saved with build number: ?
    java.io.IOException: Failed to download file from S3 bucket
    	at com.solibri.saf.plugins.bim360plugin.BIM360Resource.getInputStream(Unknown Source)
    	at com.solibri.sae.redox.Model.openModel(Unknown Source)
    	at com.solibri.saf.plugins.modelhandling.actions.OpenModelAction.a(Unknown Source)
    	at com.solibri.saf.plugins.modelhandling.actions.OpenModelAction.openModel(Unknown Source)
    	at com.solibri.saf.plugins.modelhandling.actions.MultiModelOpenAction$b.construct(Unknown Source)
    	at com.solibri.sae.ui.ae.run(Unknown Source)
    	at java.base/java.lang.Thread.run(Thread.java:840)
    Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
    	at java.base/sun.security.ssl.Alert.createSSLException(Alert.java:131)
    	at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:378)
    	at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:321)
    	at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:316)
    	at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.checkServerCerts(CertificateMessage.java:1351)
    	at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.onConsumeCertificate(CertificateMessage.java:1226)
    	at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.consume(CertificateMessage.java:1169)
    	at java.base/sun.security.ssl.SSLHandshake.consume(SSLHandshake.java:396)
    	at java.base/sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:480)
    	at java.base/sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:458)
    	at java.base/sun.security.ssl.TransportContext.dispatch(TransportContext.java:201)
    	at java.base/sun.security.ssl.SSLTransport.decode(SSLTransport.java:172)
    	at java.base/sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1510)
    	at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(SSLSocketImpl.java:1425)
    	at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:455)
    	at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:426)
    	at org.apache.http.conn.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:436)
    	at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:384)
    	at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142)
    	at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:376)
    	at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:393)
    	at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236)
    	at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:186)
    	at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
    	at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110)
    	at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
    	at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
    	at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108)
    	at com.autodesk.client.api.ObjectsApi.getClientResponse(Unknown Source)
    	at com.autodesk.client.api.ObjectsApi.downloadFileFromS3(Unknown Source)
    	... 7 more
    Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
    	at java.base/sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:439)
    	at java.base/sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:306)
    	at java.base/sun.security.validator.Validator.validate(Validator.java:264)
    	at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:231)
    	at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:132)
    	at java.base/sun.security.ssl.CertificateMessage$T13CertificateConsumer.checkServerCerts(CertificateMessage.java:1335)
    	... 32 more
    Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
    	at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:148)
    	at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:129)
    	at java.base/java.security.cert.CertPathBuilder.build(CertPathBuilder.java:297)
    	at java.base/sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:434)
    	... 37 more
      PKIX in the error log is often related to SSL certificates and firewalls.
      Try adding this line to “C:\Program Files\Solibri\SOLIBRI\Solibri.vmoptions”
      -Djavax.net.ssl.trustStoreType=WINDOWS-ROOT
      There is also another (harder) way to solve this by adding your certificate to Java keystore.
      https://sentry.io/answers/how-to-solve-pkix-path-building-failed-error-in-java/
      B 1 Reply Last reply
        b.huijskes
        @Matti Thanks you! This helped. I’ll close the topic.
        • MattiM Matti referenced this topic on
