  3. Wrong calculation about Quantities.Bounding box length/width
6 Posts 3 Posters 1.2k Views
  • H Offline
    H Offline
    HieuVH-FPT
    Hi Solibrians,
    I just encountered a bug about Quantities.Bounding box calculations
    The property is shown 856mm as bounding box width and 2.096mm as bounding box length
    But I used API getBoundingBox().getSizeY() and the code returned 0.876999 as value.
    API getBoundingBox().getSizeX() and the code returned 2.082 as value.
    Let me know if you need the model to investigate.
    Thanks
    • N Offline
      N Offline
      Nuno
      One thing that can affect quantities in Solibri is the Project Units. I think Solibri always takes the Metric System. I found some cases of other systems that would confuse Solibri.
      Regards
      Nuno
        phuc.nguyen Solibrians
        Hi @HieuVH-FPT,
        Component.getBoundingBox() gives you an axis-aligned bounding box. This might be different from the Quantities Bounding Box, which is the “tight”, non axis-aligned bounding box of the component. You can still access these through the API using Component.getBoundingBoxWidth() and getBoundingBoxLength(). These should calculate the same Width and Length in the Quantities tab.
        Hope this helps
        • H Offline
          H Offline
          HieuVH-FPT
          wrote on last edited by HieuVH-FPT
          Hi @phuc-nguyen
          Isn’t non axis-aligned bounding box of the component same as Rectangle2d object?
          I have the Rectangle2d of the component
          API getLongerSegmentLength() and getShorterSegmentLength() don’t return values same as properties
          So Component.getBoundingBoxWidth() and getBoundingBoxLength() are not related to any geometry APIs?
            Yes, Component.getBoundingBoxWidth() and getBoundingBoxLength() are not implemented by the Geometry API, but by internal Solibri library. (Legacy reasons)
            Just to confirm about the Rectangle2d case, I notice that the numbers you show from getLongerRectangleSegmentLength() and getShorterRectangleSegmentLength() are equal (floating) to those from getBoundingBox().getSizeX() and Y(). I’m unclear about which Rectangle2d is being used, axis-aligned or footprint minimum bounding rectangle. Was it component.getFootprint().getArea().getMinimumBoundingRectangle()?
            • H Offline
              H Offline
              HieuVH-FPT
              @phuc-nguyen yes, it is component.getFootprint().getArea().getMinimumBoundingRectangle()
              Even if it is axis-aligned like getBoundingBox().getSizeX() and Y(), the values are not equal to Component.getBoundingBoxWidth() and getBoundingBoxLength()
