Number of components in Space rule
Hi all,
I have problem with rule I want to make. I already had contact with someone from Solibri but unfortunatley he couldnt help me.
So this is the deal. I want to create a rule that checks whether a toilet or a bathroom has a toilet bowl.
The rule should check whether an apartment space contains a toilet space.
If a toilet space is found, it should then check whether that space contains a toilet bowl.
If no toilet space is found, the rule should then look for a bathroom space within the apartment.
- list itemlist itemIf a bathroom space is found, it should check whether that space contains a toilet bowl.
I have created this
The first one:
- is looking for space toilet and then number of components
(this works)
The second:
- First looking for space toilet, sub rule: Check only passed components
- If no space toilet, look for space bathroom: sub rule: Check only failed components
- Then check if there is a toilet bowl in the space
Now this isnt working properly. It says OK, like there is NO ISSUE. I have said minimum 20 bowls in the space and still it says OK NO ISSUES
I Hope i will get some help here
Not sure I understand but I thinkg the gatekeeper rule you have created doesnt work well.
you shuld look for “check component” view and see if the first rule pass the relevent elements. -
@aroesti Thank you
But I do this exact the same as the link.
The first rule checks if there is a toilet space in the appartement space. Sub rule i have chosen is Check only passed components
It means if it finds space toilet in appartment space, its a fail and will not pass it forward. It only pass forward if in the appartment has NO toilet space.The second rule checks if there is a bathroom space (if not found toilet space). The sub rule is check only failed components
It means it will pass forward if it finds a bathroom space in the appartment spaceIt will use these failed components to check the number of components
This is what I understand.
