  3. How to move PDF drawing
5 Posts 2 Posters 568 Views
    mikan
    Hi, I have plan drawing on PDF (vector) format, but can’t move it to the right place. Seems I can’t snap to PDF, so I can’t locate it according to 3D model.
    I’m using Office 25.12.0.84
      mikan
      Ok, printed a new PDF from Revit 2025.4 using different PDF printer, and now I’m able to snap to PDF and move it. So this has something to do with the PDF printer/driver. Native Revit PDF export might be the problem??
        Mvandenbrink
        We are having the same issue, seems like something has changed. Earlier we could indeed snap to PDF drawings but we are unable to snap and therefor align PDF drawings anymore.
          mikan
          Are you using Revit 2025? Try printing by using some other PDF driver, for me that did the trick. I have to test with Revit 2026 (for now I am blaiming Revit 2025, but the problem might be somewhere else)
          M 1 Reply Last reply
            Mvandenbrink
            replied to mikan on last edited by
            @mikan said in How to move PDF drawing:
            Using Revit 2024 in this case. But got the same results with Revit 2025 using the inbuild PDF exporter. When using Print to PDF or a plugin the PDF does work fine with Solibri.
            @Solibrians Any ideas how to fix this?
