  3. Check only the first of the found duplicates
3 Posts 1 Posters 514 Views
  • _c__ Offline
    _c__ Offline
    _c_
    I have a rather bad set of ifc files for Provision for Voids with loads of geometric duplicates. I cannot send it back, unfortunately.
    I need to create a gatekeeper rule that finds all duplicates, then performs checks on the first found, ignoring the rest. Is it possible or does it work only through selection basket?
    c
    • _c__ Offline
      _c__ Offline
      _c_
      Using the rule SOL 1 on three exact duplicates, it is difficult to deciffer this combinatory display:
      If there are more duplicates, each combination is displayed. Can we summarize them in one entry, where only the first is “good”?
      c
      • _c__ Offline
        _c__ Offline
        _c_
        wrote on last edited by _c_
        I have to write this workflow down, because it might be useful to others or might be entirely wrong and someone will show me better, … anyway, here it is:
        • create a SOL 1 rule parsing for duplicates:
        • make sure that all dups are rejected, but the first one:
        • select all items (click on “=”) to make a starting selection basket, including the dups. In this particular case it was these 3 Models:
        • run the SOL 1 rule, then right-click it and select all rejected:
        • open the “Checked components” view, select all lines and click on “-” to remove them from the selection basket.
        • Now you have a selection of everything, excluding the dups. It is advisable to save this selection by name in the Selection Basket:
        Now you can filter by selection basket the results of your rules:
        c
