  3. Autorun Timestamp in report names
4 Posts 3 Posters 603 Views
    john
    Hi All.
    Is it possible to get the date in the report names when using autorun.
    example: “2026-04-16_Result SummaryReport”
    best regards John
    viktorwiklandV 1 Reply Last reply
      If you mean the report file names, then you need to ask AI to write a python script that creates an Autorun xml with the current date and runs it.
      • viktorwiklandV Offline
        viktorwikland
        replied to john on last edited by
        @john said in Autorun Timestamp in report names:
        I have switched jobs since last time I did this and I cannot recall exactly how I did this…
        But I started did something along the lines of;
        I saved my file with a placeholder for date
        <itoreport name=“FileName” file=“FilePath\C\Modell\Versions\currentDate_Solibri Autorun.xlsx” />
        And then in my .bat that runs the .xml i had a line of code that launched a .ps1 that replaced all placeholder values with the current date
        Example .ps1:
        $date = Get-Date -Format “yyyy-MM-dd”
        Get-ChildItem -Filter “currentDate” | ForEach-Object {
        $newName = $.Name -replace “currentDate”, $date
        Rename-Item -Path $
        .FullName -NewName $newName
        Hope this helps somewhat 🙂
          john
          allright thanks for the help you guys 🙂
          I’m not that firm in coding so I think I’d have to ask someone to make it work. looks like there is some different workaround methods we can use. I just found it strange that this was not a standard function
          thanks again 👌
