Visualization displays differently after re-opening smc
Hi @Solibrians
I’m experiencing with a visualization issue.
After running a rule, the dimensions are visible through the walls in the 3D view.
However, after I save and re-open the SMC, the dimensions are no longer visible.
Please help investigate
Thanks -
@HieuVH-FPT said in Visualization displays differently after re-opening smc:
Which version of Solibri you are using?
Have this setting on:
Could you share a code snipped where the dimension is created?
Hi @Matti
I’m using newest version 26.4.1 and that setting is on.
Due to specific client requirements, I had to customize the dimensions. Therefore, the “dimension” in the code is actually created using visualization.Lines.create() instead of VisualizationItem.createDimension() -
With following code you can set your custom VisualizationItem as dimension:
private enum MeasurementType { DIMENSION, VERTICAL_DIMENSION, HORIZONTAL_DIMENSION, COMBINED_LENGTH, POLY_LINE, ANGLE, FACE_AREA, POLY_AREA, VOLUME, POINT, POINT_X, POINT_Y, POINT_Z, CIRCULAR_ARC, OTHER; } private static final String DELIMITER = "#"; private static String createKey(MeasurementType type) { return "Dimension-" +type + DELIMITER + System.currentTimeMillis() + DELIMITER + UUID.randomUUID(); } VisualizationItem vi = .. vi = vi.withUserData(createKey(MeasurementType.DIMENSION));
