  3. Batch creating issues - viewpoints revit
3 Posts 2 Posters 841 Views
    Samb
    Hi Solibrians!
    I’m currently working with some big project and trying to automate some of my task. One of those is, obviously, checking the models. The rules i created find the problems i need but now i’m trying to automate the creation of the issues. Not only the overview issues but each issue individually.
    Also, I’d like to include the nearest grids in the description. (Bimcollab-zoom-like). This because the link between solibri and revit doesn’t include the correct viewpoints - I guess i’m not the only one with this problem… so if somebody has a solution to this one, that would be great!
    Thanks in advance!
    • I Offline
      I Offline
      Ion Chan
      Hi Samb,
      I believe your workflow would be adding slide to each issue, then create new presentation by checking result, and finally export the presentation as a BCF file or link to a BCF server.
      It seems you can only create the issue one by one as you need to add slide manually for create presentation. I hope SOLIBRI can provide a feature to batch add slide to all/selected issues.
      S 1 Reply Last reply
        Samb
        replied to Ion Chan on last edited by
        Hi @Ion-Chan ,
        As you discribed it, thats my current workflow. but it takes up a lot of time to add a slide to each issue…
        What about the viewpoint that is missing in revit… does anyone have this problem?
