  3. Problem with opening SMC file with new release 9.10.8.29
4 Posts 2 Posters 554 Views
    wrote on last edited by agroni
    After updating my Solibri to 9.10.8.29 I am not able to open my old files that had previosly crashed. This problem has been previously discusse here.
    I assume since all my actual files have been revived from SMC Backups (renaming them), they cannot be opened now with the new version.
    Other files that previously were not experiencing problems, can be opened with the new release.
    This is the message that I receive:
    Diese Solibri-Datei kann mit dieser Version nicht geöffnet werden.
    Mögliche Gründe:
    - Das Modell wurde mit einer neueren Programmversion gespeichert.
    - Das Modell kann nur geöffnet werden, wenn eine bestimmte Erweiterung installiert ist.
    Anwendungs-Build-Nummer: 9.10.8.29
    Das Modell wurde mit einem Build mit der Nummer gespeichert: 9.10.6.23
    java.lang.ClassNotFoundException: com.solibri.saf.plugins.unitsettingplugin.AngleFormat
    	at java.net.URLClassLoader.findClass(Unknown Source)
    	at java.lang.ClassLoader.loadClass(Unknown Source)
    	at java.lang.Class.forName0(Native Method)
    	at java.lang.Class.forName(Unknown Source)
    	at com.solibri.sae.redox.SAEObjectInputStream.resolveClass(Unknown Source)
    	at java.io.ObjectInputStream.readNonProxyDesc(Unknown Source)
    	at java.io.ObjectInputStream.readClassDesc(Unknown Source)
    	at java.io.ObjectInputStream.readClass(Unknown Source)
    	at java.io.ObjectInputStream.readObject0(Unknown Source)
    	at java.io.ObjectInputStream.defaultReadFields(Unknown Source)
    	at java.io.ObjectInputStream.readSerialData(Unknown Source)
    	at java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
    	at java.io.ObjectInputStream.access$800(Unknown Source)
    	at java.io.ObjectInputStream$GetFieldImpl.readFields(Unknown Source)
    	at java.io.ObjectInputStream.readFields(Unknown Source)
    	at com.solibri.saf.plugins.filteringplugin.ClassAndPropertyFilter.readObject(Unknown Source)
    	at sun.reflect.GeneratedMethodAccessor67.invoke(Unknown Source)
    	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    	at java.lang.reflect.Method.invoke(Unknown Source)
    	at java.io.ObjectStreamClass.invokeReadObject(Unknown Source)
    	at java.io.ObjectInputStream.readArray(Unknown Source)
    	at java.io.ObjectInputStream.defaultReadObject(Unknown Source)
    	at com.solibri.sae.greenox.Constraint.readObject(Unknown Source)
    	at sun.reflect.GeneratedMethodAccessor89.invoke(Unknown Source)
    	at com.solibri.sae.redox.Property.readObject(Unknown Source)
    	at sun.reflect.GeneratedMethodAccessor28.invoke(Unknown Source)
    	at com.solibri.sae.redox.Model$ClassNode.readObject(Unknown Source)
    	at sun.reflect.GeneratedMethodAccessor52.invoke(Unknown Source)
    	at com.solibri.sae.redox.Model.readObject(Unknown Source)
    	at sun.reflect.GeneratedMethodAccessor91.invoke(Unknown Source)
    	at java.io.ObjectInputStream.readObject(Unknown Source)
    	at com.solibri.sae.redox.Model.b(Unknown Source)
    	at com.solibri.sae.redox.Model.openModel(Unknown Source)
    	at com.solibri.saf.plugins.modelhandling.actions.OpenModelAction.a(Unknown Source)
    	at com.solibri.saf.plugins.modelhandling.actions.OpenModelAction.openModel(Unknown Source)
    	at com.solibri.saf.plugins.modelhandling.actions.MultiModelOpenAction$a.construct(Unknown Source)
    	at com.solibri.sae.ui.aj.run(Unknown Source)
    	at java.lang.Thread.run(Unknown Source)
    How can I repear this problem???
    All my files in one project are corrupt according to the new release. It says that I need some sort of extension to open this file?!?!?
    I will reinstall the old version, but I would like to migrate somehow this one project to the new release.
    @Solibrians Tips@Tricks?
    TriPoint GmbH
    www.tri-point.at
      We’ve noticed this problem ourselves and working on a quick hotfix.
      Pasi
        great to hear that 🙂
        When can we expect the new hotfix?
        Thanx for the great work you are doing 👍
        TriPoint GmbH
        www.tri-point.at
          ASAP. The fixing is already in progress.
