  3. Rule #23 - Touching Components
rule 23touching
2 Posts 2 Posters 674 Views
    shapeless
    Hey there!
    I am currently working on developing rules for “clash” detection. In conjunction with this I stumbled across this rule. Since some elements in ArchiCAD are not recognized as “clashing” or better put “not in the right position”, e.g. walls and slabs are mostly joined, no matter at which height.
    Now I want to make sure that there is always an error when the slab isn’t located at the top or bottom of a wall.
    Since we decided not to work with Solibri components when possible but rather with classified elements I was wondering whether this rule only works with components.
    When working with classified elements on both sides of the rule and checking for elements taken into account only the elements on the left side are selectable. Hence the rule is not applicable on the model.
    It only works if I check elements against each other individually
    Setup with classification (more than 1)
    left
    Include | any component | classification xy | one of | column
    right
    Include | any component | classification xy | one of | slab
    Include | any component | classification xy | one of | roof
    Include | any component | classification xy | one of | wall
    >>> doesn’t work
    Setup with classification (1)
    left
    right
    >>> works
    Setup with components (1 or more than 1)
    left
    Include | column | discipline | one of | architecture
    right
    Include | slab| discipline | one of | architecture
    Include | roof| discipline | one of | architecture
    Include | wall| discipline | one of | architecture
    >>> works
    • Lauri LuomaL Offline
      Lauri Luoma Solibrians
      @shapeless the “component” column determines if the condition is “OR” or “AND”. If you have set it to be the same type of component (also “any component”) the condition is “AND”. That is why the first setup where all the rows have “any component” it tries to match the component to all the conditions. To make it work, you can choose “one of” and multiple classification values on one row:
      Include | any component | classification xy | one of | slab, roof, wall
      When creating a rule, it helps to first choose the rule under ruleset manager and then open the parameters of this rule under checking layout. There you can test what the filter is returning by pressing “=” to set the components to be visualized by the selection basket. This way you can make sure the filter is working as you’d expect.
      I hope this helps,
      best,
      Lauri
