  3. Set Tolerances for Results Returned in Comparison Rule 231 for Volume Difference
3 Posts 3 Posters 747 Views
    scorney
    I’m doing a model comparison check but would like to only see the results which are above a certain volume, is there a way to do this? Or could it be done through the API?
    Thanks,
      TRS_LUD
      i´ve got a similar question:
      i would like to compare space area and required space area with a certain tolerance.
      i figured that rule 231 might be the best choice to do that, but i cannot find a way to set a tolerance to ignore some issues, where the difference of space and required space is e.g. less than 1%.
      please see the attached picture below. the rule is working so far and replying issues when NUF_soll and Area are not equal. Now I want to get issues below a certain difference ignored.
      Is there a way to implement that in Rule 231, or in any other way?
        @scorney What do you mean by volume here? Would you only want to check components that are larger than a given volume?
