  3. Classifications not recognising parameter values which are defined in property sets
5 Posts 2 Posters 1.5k Views
  • MaxCallaghanM Offline
    MaxCallaghan
    On one of the projects I’m working on we’ve set up the IFC export process to export required parameters in a property set.
    When loaded into Solibri, if I navigate to an element with the property populated I can see it in the info window as expected.
    However, when I brought in classifications which have rules which rely on the values of these properties, whilst I can set them as a column, none of the components are being classified. It appears that all the elements with the required properties aren’t recognised by the classification function?
    Any ideas? Information Takeoffs also appear affected.
    MaxCallaghanM 1 Reply Last reply
      MaxCallaghan
      replied to MaxCallaghan on last edited by
      @MaxCallaghan Issue Resolved. There was a space on the end of one of the parameter names.
      • cpreidelC Offline
        cpreidelC Offline
        cpreidel
        Hey @MaxCallaghan,
        sometimes typos, whitespaces or similar uncommon ways how the PsetName or the Property itself is written cause that classification or ITO are not working properly. Could you check in your physical IFC file with a Text Editor these values? Simply search for “NBO_AssetData(Type)” and one of the affected Property Names, such as “Ss Classification Description”.
        Thanks
        Cornelius
        • cpreidelC Offline
          cpreidelC Offline
          cpreidel
          Just a second too late 😉
            MaxCallaghan
            replied to cpreidel on last edited by
            @cpreidel indeed, thanks anyways!
