  3. Rule 203 - how to generalise?
2 Posts 2 Posters 617 Views
  • N Offline
    N Offline
    Nathan Ashton
    Hello Solibri Society,
    I am having trouble generalising the 203 Rule.
    Basically I need to check if a particular Property Set exists in the modeled components; I don’t need to do a detailed check just yet of what those Properties are and if they are correct.
    On the Help page for 203 I see this text: The rule checks that the model has required property sets and properties. It also checks, that properties have values (if required), and the type of the values is correct.
    Could anyone help me to generalise this rule or suggest another Rule to use please?
    Thanks in advance!
    Nathan Ashton
    BIM Coordinator
    Nokera Planning, Leipzig, Germany
      Stefan L.
      simply add the elements to be checked in the upper field,
      then add a line like this in the lower field (checked PSet here is “Text”):
      Stefan
