  3. Autorun autocomment accepted results
7 Posts 4 Posters 1.5k Views
    twosk
    Hi, I was testing if it is possible to manually go through checking results, accept what needs to be accepted, save the file and after that run autorun to make slides.
    In documentation I read that issues are created only for these results:c1996227-7f0c-459b-8d33-1e25937c49f8-image.png
    I problem I have is that autorun still creates slides for manually accepted results.
    However I can filter those slides by checking decisions and delete the slides.
    Does it suppose to work like this?
      The <autocomment/> is not filtering manually accepted or rejected issues. It could skip the accepted ones and then it would work in your process. I wll add a ticket for this.
        twosk
        @Matti-Kannala great, it would help in cases where one would manually go through results and decide in each case if the results are acceptable or not and after that autorun would make slides.
        Is it possible to assign a slide to a specific person or add a due date with autorun?
          lraimo
          @Matti-Kannala any updates on this subject?
            lraimo
            @Solibrians
            Any updates? Would like to use autorun to add slides but only for rejected results
              Unfortunalely not yet in the next release v. 9.13.8. Thanks for reminding.
                stefkeB
                Any updates to this? We too are trying to generate BCF reports, but need to filter out the “accepted” issues.
