  3. BCF Live Connector | Cannot filter
20 Posts 11 Posters 5.1k Views
    replied to Anil on last edited by
    @anil @twosk
    Make a backup and empty the folder:
    C:\Users\USERNAME\AppData\Roaming\Solibri\filtermap
    That folder contains the saved filters. Might be that the there is an invalid saved filter that causes the problem.
    gvbeersG 1 Reply Last reply
    • gvbeersG Offline
      gvbeersG Offline
      gvbeers
      This path should work for all users %appdata%\Solibri\filtermap
      G. van Beers
      Project coördinator BIM
      LinkedIn: https://www.linkedin.com/in/gvanbeers/
        twosk
        @Anil @matti-kannala @gvbeers thank you, now filter works
          Seba
          I have the same problem, and the the solution proposed by @Matti-Kannala, does not work for me. Is there anything else that can be done? I know it has worked before, and this week I noticed that it doesn’t work.
            lraimo
            Filter with Trimble Connect do not work
            • W Offline
              W Offline
              Wing Mang
              I have the same problem too
                lraimo
                @Solibrians
                Any updates on this matter?
                  If I remember correct, this is a Trimble Connect issue. They need to implement the filtering.
                    lraimo
                    @Pasi-Paasiala
                    Is this missing from API? Because Trimble Connect Web has it.
                    More info https://docs.browser.connect.trimble.com/bcf-topics/topics-listing
                      @lraimo Trimble connect does not have this implemented in their implementation of BCF-API.
                        lraimo
                        I have communicated this to Trimble.
                        @Solibrians Have you also communicated this to Trimble? Filtering is very important when project is big with hundreds or thousands of issues
                          LariMatias
                          I’ve communicated this to Trimble as well via their support ticket service or such.
                          Edit: Corrected grammar.
                            twosk
                            I think this is not CDE , but solibri’s problem
                            1.At the moment filter works, but sometimes I can not import all selected issues, i need to mark it.
                            2.Imported slides contain wrong section and model selection. Exported views are correct in the CDE (dalux).
                            3.I have tried both dark and light UI and somewhat outcome regarding BCF live connector is different.
