Join our Solibri Beta Group!
@BvanDalsum I have sent you the instructions in this case by e-mail. Please let me know if it has worked
@lraimo Invitation has been sent
Where do i find the Clash Detection Matrix?
@BvanDalsum it is rule #245. This resource comes along with the Beta installer
Hi @Paul-Linder
I have a problem with the installation of Solibri Beta. I have follow all the steps you write down on the mail: I
have unistalled the old solibri beta versions and I create a new directory. I have completed the installation of the exe but when I run Solibri Beta, this window appears:
What can I do?
Thank you,
Viola -
Hi @violarenzoni, we did some changes in the background for your account. Please try it again and delete the folder C:\Users \ %userprofile%\ .solibri-beta
@Paul-Linder thank you, now it works!
Hello @Paul-Linder
I have the same error as post #6: I can install the beta version, but cannot sign-in.
Thanks for your help! -
Hello @Paul-Linder
I also have the same issue as post #6. I’ve installed the beta version, but unable to sign-in.
Are we supposed to use our Solibri Society username and password, or our credentials linked to our Solibri licence?
Thanks in advance for your assistance with this issue. -
@dgbtransport the access is now available. Much success with testing
Thank you, Paul. It was great chatting with you.
Hi @Sini-Aalto, Hi @Paul-Linder,
I’m going to test the One Click LCA BETA Plugin integration in Solibri. Unfortunately I can no longer access the Solibri Beta SSC to download the exe file. How can I do? Thanks in advance! -
@paola-bronzo now it should work
J jakub.rusin referenced this topic on
P Paul Linder referenced this topic on
Dear Paul, I want to test the OpenCDE API in connection wbetween your software and our BIM&Scan-OpenOp system. I shall send the details via email for logging into our UAT environment for testing on your end.
@Dr-ShawnO-Keeffe you received an invitation
Dear @Paul-Linder,
I would like to test the Solibri BCF Live Connector with the BCF module of Mezzoteam. I will send you an email with the detailed information required to connect to a Mezzoteam test workspace so that you can perform tests on your side.
Could you please let me know how I can obtain BETA access to test this integration?
Thank you in advance for your support.
Best regards, -
T tonigyllenberg referenced this topic on
Hello @Paul-Linder after registering for the new beta group, will we receive a confirmation email? We want to connect our BCF/IFC Software “KISS-BIM” to the Solibri BCF-Live-Connector. Do you need any further information? Thanks in advance and best regards, Thorsten
@nuce said in We are moving - Join our new Solibri Beta Group!:
Hello Thorsten!
We received the request to join beta. In order to add the server to beta, we need the server details. I sent over an email on 4.12, and then on 26.1 to ask for the server connection details. Please provide these by responding to the email, so that we can add the server and members to beta.
@tonigyllenberg
can i register for the bèta group?
