error message in ruleset-any clue why?
Hi
I’ve used ghatgpt to create some rulesets for architectural, Structural and MEP to be used in Solibri but when I’ve loaded them I got this error message.
Can anyone help on why this happens and how to fix it?Thx
I know I am a little “over my league” but it would be great to solve this out.
Thx -
@student23027 said in error message in ruleset-any clue why?:
You created the .cset with ChatGPT?
JNS I don’t know what is the meaning of .cset. I’ve prompted chatgpt to create a ruleset to be imported to Solibri for a certain number of properties and he created the code and gave me the instructions to save it to .XML. That’s all I knew to do.
And what does ChatGPT say when you tell it about the error or when you ask about .cset?
I’ll give you a hint: Resources are currently not clear-text .xml …
I’ll try that. Thx
The information I got from Chatgpt was to produce a .XML file not a .cset file, From what I understand Solibri accepts three formats cde, XML and ids, right?
That was a sarcasm.
The information I got from ChatgptChatGPT is not the source of all wisdom.
CDE is not a format.
No to XML (at least not in the latest version).
IDS is a different story.Have you considred to read the manual, create a simple rule first, import maybe .xls into #231, or to use the search function here?
I’ll try to do that. I went with the error message back to chatgpt and it told me my file wasn’t following the Solibri rule table structure. I asked for instructions and it gave me instructions to do it manually but the fields it proposes don’t show the same way in the newruleset in Solibri. I’ll have to approach it differently.
Thx for your support
Luis -
More info about IDS: https://www.solibri.com/news/everything-you-need-to-know-about-information-delivery-specifications
It could be possible to give IDS files to ChatGPT and ask modify to fit your specs.
@Matti-Kannala said in error message in ruleset-any clue why?:
True, but letting ChatGPT fantasize about something which should in fact be really precise (like IDS) is probably not a good idea (at the moment). Though on the other hand this topic is really interesting as it would be powerful to make it possible to have a view which allows OpenAI API integration to use that to communicate with Solibri model data like checking results.
