  3. Clash Matrix does not ignore components only in same model?
6 Posts 2 Posters 1.4k Views
    Simone Maioli
    Is it possible to insert a filter in the clash matrix rule that ignores the components present in the same model and not model and layer?
    otherwise it continues to give me false positives for the groupings I want
      Add one level to the matrix specifying the model.
      • could be model category, model short name, model name, or classification
        Rows level as filtering models from set A
        Column level as filtering model from set B
        Then all results will be component from A vs component from B
        Simone Maioli
        I thought about it but it’s a bit boring because I often work with federated infrastructure models with more than 15/ 20 models and as many WBS, and for those the matrix starts to get complicated to compile
          The option “In the same Layer and Model” could be split:
          • in the same System
          • In the same Layer
          • In the same Model
          this would solve your problem.
          S 1 Reply Last reply
            Simone Maioli
            it would be great, for example naviswork this function is implemented.
              Simone Maioli
              @Matti is it known if this feature will be implemented in the next updates?
