Clash Matrix does not ignore components only in same model?
Is it possible to insert a filter in the clash matrix rule that ignores the components present in the same model and not model and layer?
otherwise it continues to give me false positives for the groupings I want
Add one level to the matrix specifying the model.
- could be model category, model short name, model name, or classification
Rows level as filtering models from set A
Column level as filtering model from set B
Then all results will be component from A vs component from B
I thought about it but it’s a bit boring because I often work with federated infrastructure models with more than 15/ 20 models and as many WBS, and for those the matrix starts to get complicated to compile
The option “In the same Layer and Model” could be split:
- in the same System
- In the same Layer
- In the same Model
this would solve your problem.
it would be great, for example naviswork this function is implemented.
