  4. profile.ini and paths.properties
14 Posts 5 Posters 4.3k Views
  • _c__ Offline
    _c__ Offline
    _c_
    I am now testing a path different than Public at home on OneDrive, files locally stored (I don’t think that it is relevant in this case, but just in case).
    Most paths work after translating them, some don’t. What else could be wrong?
    This path works on Save but not on Open:
    #Open and save .classification
    classification_directory = C:\Users\xx\OneDrive\Solibri\Solibri Shared Resources\Klassifizierungen
    This always works:
    #Import and export .xls classification rules and default classification names
    classification_settings_directory = C:\Users\xx\OneDrive\Solibri\Solibri Shared Resources\Klassifizierungen\Daten
    c
    • _c__ Offline
      _c__ Offline
      _c_
      wrote on last edited by _c_
      This path never works:
      #Open .xls checking templates
      checking_template_directory = C:\Users\xx\OneDrive\Solibri\Solibri Shared Resources\Berichtsvorlagen\Zusammenfassung
      c
      • _c__ Offline
        _c__ Offline
        _c_
        This also never works, the excel files are never found:
        #Open .xls templates for ito
        ito_template_directory = C:\Users\xx\OneDrive\Solibri\Solibri Shared Resources\Auswertung\Vorlagen
        c
        • _c__ Offline
          _c__ Offline
          _c_
          The way this could optimally work, is that there would be no need to translate.
          There are problems in the language management of Rules and more. The problems amplify across Anywhere<>Office users.
          In international offices working on projects across multiple language areas, it is difficult to run Solibri optimally. We are now thinking to have Solibri installed both in English and German, with two office shared resources.
          The default paths could also be defined relatively -is this coming in the new Solibri? That would be so good.
          c
          • _c__ Offline
            _c__ Offline
            _c_
            BUMP!!!
            Hallo, now is end of 2024 and the issues are still there.
            Please fix this as it is a nightmare to use common resources in an office without a proper file path system.
            c
              @_c_ Have you considered creating language-specific roles that point to the correct paths? The roles could all be in one folder with proper names, like English/Deutsch.
              • _c__ Offline
                _c__ Offline
                _c_
                Hallo, yes, I did. But as described above, not all paths work. If you have more documentation as otherwise available that would be good. Something is clearly missing.
                c
                  Following this up as well as to me it’s not clear enough how this should work. Is it supposed to work nowadays or is time not worth trying to figure this out cause it ain’t work anyhow?
                  • _c__ Offline
                    _c__ Offline
                    _c_
                    Hallo, this is primarily a documentation issue. But yes, I also gave up sharing office wide, I use now only a SharePoint path, whereby, from inside Solibri, I am really never sure if I am editing there or where.
                    I think I can speak for most when I wish it was easier and more transparent to manage Solibri resources. The UI is very confusing in this sense. For example: It would be useful to display somewhere the path of the active rule while we are editing it.
                    c
                      replied to _c_ on last edited by
                      There is certainly a lot to say on this topic. However, it seems that nothing has changed here for quite some time. The easiest approach to resource management and deployment still remains unclear to me, but is probably done outside of Solibri.
                        Thanks for reminding about this. We try to improve the documentation and fix the paths that are not working (e.g. classification_directory)
                          brinkman
                          With every update, and especially for new users, it’s always a hassle to get the roles configured correctly. Let alone the right settings for everything that isn’t included in the role—things like dimensioning and disciplines.
                          So there’s also a strong desire here to improve this.
