  4. Loading required values from Excel fails on booleans
4 Posts 2 Posters 1.5k Views
  • _c__ Offline
    _c__ Offline
    _c_
    wrote on last edited by _c_
    I don’t think that this is fully operational: loading required property sets from excel doesn’t seem to work for boolean.
    • Create a rule 203 (Required Property Sets)
    • Test operational feature by loading a manual entry with a boolean value that must be True, like this:
    • Test not operational feature by loading the “True” value from excel. I used the standard template out of the box:
    This never sets to “True”, it results always in “True or False” (any value):
    c
      wrote on last edited by Matti
      The German Excel example for this rule has a problem.
      The true/false value in Excel for German Solibri needs to be as Text “Falsch” or “Wahr”. The Excel boolean value is not working.
      Here is the fixed example.
      Erforderliche Eigenschaftensatze.xlsx
        Note: There will be small improvement to this rule in the next release:
        • Adds support for =, ≥, ≤ operators in Excel import
        • Adds support for Excel boolean cells with all languages in Excel import
        • _c__ Offline
          _c__ Offline
          _c_
          Thank you!
          c
