  3. Models real slow, freezes and shutting down
13 Posts 4 Posters 577 Views
  • BvanDalsumB Offline
    BvanDalsumB Offline
    BvanDalsum
    wrote last edited by
    Since the update to 26.4.1, the models have become very slow as soon as you create a sectioning
    The model even freezes, and sometimes Solibri closes.
    It seems to be related to enabling clipping gridlines and show labels.
    does anybody has a solution or a work around?
      Yes indeed, this sluggishness in 3D (and also visible in BCF when vizualising issues), was an unforeseen negative impact of the new additions to sectioning. This has been addressed in 26.6.0 and is available for beta testing as we speak!
      As a workaround, reducing and hiding texts, markups, grids and sections should improve the situation quite a lot.
      • HartwigH Offline
        HartwigH Offline
        Hartwig
        Testing the 26.6.0.134-BETA, I also see significant degradations when working with sections. That’s not a small detail, it is a function we need every day hundreds of times. Frankly speaking, all new versions after 25.12.0.84 are not useable for productive purposes. But now we have a KI Assistant and In-app Notifications. Wow.
          replied to Hartwig last edited by tonigyllenberg
          @Hartwig said in Models real slow, freezes and shutting down:
          Hello Hartwig!
          Thanks for your feedback, it’s always a pleasure hearing from you.
          Could you be a bit more specific on the degradations you’re referring to with Sections? What is it that actually is taking more time in your case?
          HartwigH 1 Reply Last reply
          • HartwigH Offline
            HartwigH Offline
            Hartwig
            replied to tonigyllenberg last edited by
            Hi Toni,
            simply said, it feels like working on an 80386 machine when trying to move a section plane 😉
            In 25.12 everything was fine. Now it is interrupted and feels like bubble gum. While moving the section the program needs nearly 50% of CPU power. What does it do in the background? See the two files attached, I can’t work with this.
            It seems that it has to do with checking. After opening a file it runs like expected. As soon as you clicked a checking result, Solibri goes to “slow mode”. After that even deleting all rules does not change anything until an app restart.
            Regards
            Hartwig
            25.12.mp4
            26.6.mp4
            BvanDalsumB 1 Reply Last reply
              Thanks @Hartwig for the videos, this doesn’t look at all as it should. We haven’t seen such degradation in our test models but we will dig into this right away. You wouldn’t perhaps be able to share that model for testing purposes would you?
              • HartwigH Offline
                HartwigH Offline
                Hartwig
                Have sent you a like, hope it helps. By the way… the new options for sections are really helpful (after fixing the small problem…) Next step should be an option to rename the section. Thanks!
                  BvanDalsumB Offline
                  BvanDalsum
                  @Hartwig @tonigyllenberg
                  This is exactly what we’re experiencing.
                  It’s already a lot faster than in version 26.4, but it’s certainly not where it needs to be to make working with the models a pleasant experience.
                  • HartwigH Offline
                    HartwigH Offline
                    Hartwig
                    replied to BvanDalsum last edited by
                    Would be interesting to know what kind of graphic adapter you’re using. I compared my office machine (Nvidia super expensive, 3 years old) with my private laptop (Intel Iris, 5 years old and not made for 3D jobs). Surprise… in some situations the laptop is smoother when moving section planes. 😵
                    But Toni is investigating, so we can be hopeful 👍
                      replied to Hartwig last edited by Ricardo
                      @Hartwig Did you check if Solibri is actually using the Nvidia display adapter?
                      With our dual GPU laptops, Solibri is defaulting to the integrated display GPU instead of the Nvidia GPU… You have to manually select the GPU in the Nvidia control panel.
                      It’s probably a Windows (11) bug and not Solibris fault, but F me I am getting so tired of that issue. With new updates the problem comes back.
                      • HartwigH Offline
                        HartwigH Offline
                        Hartwig
                        Hi Ricardo, thanks for the hint. But yes, it’s already running on the Nvidia chip, without manual changes in all versions of Solibri.
                          So we’ve done some more digging. Indeed 25.12 is faster for a few reasons, but the most important reason is that it does not include any of the newer options regarding grids, sections and markups.
                          Our Lead dev has spent some time Friday optimizing the sectioning performance altogether and with the release we’ll have an overall better performing sectioning tool.
                            BvanDalsumB Offline
                            BvanDalsum
                            @tonigyllenberg
                            It’s not just the sectioning.
                            Browsing through issues in a report (and thus loading the images) takes a long time, especially when an image contains a sectioning.
                            If you turn off the grids in a sectioning and try to move it, the grids will be back on after the immage rebuild. and that takes a really long time.
                            I hope all of this has been fixed in version 26.6.
                            In the beta, the issues are still present.
