  3. How to remove a decimal when using a formula?
3 Posts 2 Posters 397 Views
    I try to use the thickness of elements in a Formula, but it puts a decimal in the results. Is there a way to remove this decimal? I thought perhaps that the Units settings had something to do with it, but that does not seem the case.
    • jakub.rusinJ Offline
      jakub.rusin Solibrians
      Hi @Ricardo
      Unit settings control display formatting in tables and reports, not how numbers appear when you concatenate them in a classification formula.
      To remove the decimal in the classification name, you could try to wrap the thickness reference in FIXED(E;0) or INT(E) in your formula.
      Hope that helps!
        replied to jakub.rusin on last edited by
        @jakub-rusin That works great, thanks!
        • jakub.rusinJ jakub.rusin marked this topic as a question on
        • jakub.rusinJ jakub.rusin has marked this topic as solved on
        • jakub.rusinJ jakub.rusin unlocked this topic on
