Java4Shell vulnerability (CVE-2026-114938)
Dear Society members,
We are aware of the recently disclosed Java4Shell vulnerability (CVE-2026-114938) and are actively working to address it. Updates to our cloud-based services are being applied in the background. Once an updated Java version is available, we will also release an updated installer for the desktop application.
Workaround:
As a temporary precaution, customers using the desktop application may add the following option to their .vmoptions file:-XX:-UseBASE64Intrinsics
This setting disables the affected Java Base64 optimization and helps reduce exposure while we complete and distribute the permanent fix.
To apply this option:
- Close Solibri.
- Open the Solibri.vmoptions file in the installation folder, typically C:\Program Files\Solibri\SOLIBRI.
- Add -XX:-UseBASE64Intrinsics on a new line.
- Save the file and relaunch Solibri.
We will share further updates as they become available.
The Solibri team
@tonigyllenberg
Is this workaround also applicable to version 25.12 and earlier versions, including the Solibri “Anywhere” version that is installed alongside the newer 26 version(s)? -
@Peter-Vlug said in Java4Shell vulnerability (CVE-2026-114938):
Check the Java version from logs or File->Help->System Information->Java Version
If you have OpenJDK 17.0.6 or later -> apply the fix.
The older Java versions don’t have the Java4Shell vulnerability.
