Update Prompt
Why does de update Prompt not appear as aspected.
For some time now, it hasn’t always appeared, making it unreliable.
This is important because, unfortunately, collaborating on a single model isn’t possible within Solibri.
That’s why it’s important for everyone to work with the latest versions of the IFCs, which isn’t currently possible because we can’t see that a new model has been added to the folder.
The only way to do this seems to be the old-fashioned way: sending a message to all team members with a notification.We’ve been working with a network drive that stores the project files for several years now.
We never had any problems with this before, and nothing has changed in that regard. -
@BvanDalsum
This might be related to authentication.
In Solibri, you can choose to have your login credentials remembered—which is certainly more convenient, as it saves you from having to log in to ACC or SharePoint every single time.
However, at our company, you are required to re-authenticate every three weeks.
If this isn’t done, it can sometimes look like you have an active connection, when in reality, you no longer do.
Therefore, re-establishing the connection once a day or once a week might help, and would likely resolve the issue with the prompt. -
that is not the case here,
This isn’t about an environment you have to log into.
If you’re connected to the network via an Ethernet cable or Wi-Fi, you have access to this drive.
What strikes me first is how the update behaves.
Sometimes the prompt appears within a few seconds, and sometimes it doesn’t appear at all. -
@BvanDalsum I’m seeing the same behavior. If I restart the coordination model, the prompt appears almost immediately.
If the model has been running for a while, however, there can be a delay of several hours before the prompt is triggered. -
Hi @BvanDalsum ,
Like @bhavekes mentioned, when you first open the .smc file, the update is checked immediately.
After that, If you have your update settings to prompt, Solibri checks for updates frequently, polls the CDE to see if there are new versions of the models.Please also ensure you’re running the latest version of Solibri.
If this issue persists please send us a support case at [email protected] share the details of how you have your shared location setup and we will investigate further.
Thank you.
I don’t know if @BvanDalsum means the same, but for me in the latest release (26.9.1.126) this window does not pop up every time:
(the blue highlighter is from our presentation)
@jacob-wangara The SMC file remains open all day and is used by about four people per project. As soon as new models are added or ITOs and classifications are created, everyone downloads the SMC from a fixed location. To update models, we use the Prompt setting; the advantage of this is that everyone is always working with the latest models. (That’s why it’s so important that the update prompt appears as soon as new IFC files are available.)
We don’t use the latest version of Solibri, but version 26.6.1.120 (everyone). A few of us check whether an update is worth the effort, but we sometimes skip an update because we think it’s important that everyone uses the same version, and this is quite difficult to manage from an IT perspective.
