  4. Unable to configure BCF connector
7 Posts 5 Posters 1.4k Views
  • EgilsBE Offline
    EgilsBE Offline
    EgilsB
    Colleague of mine has encountered greyed out buttons in BCF Connector configuration under options stopping them from configuring connection to BCF Issue manager.
    His peers with same hardware, OS and Solibri build don’t have this issue.
    Screenshot to be attached when received.
    W10 17134.1246
    Solibri 9.10.5.18
    EgilsBE 1 Reply Last reply
    • EgilsBE Offline
      EgilsBE Offline
      EgilsB
      replied to EgilsB on last edited by
      Add Server… has no response
        Hi. In order for us to solve this issue, we would need the application logs. Those can be sent to [email protected] and are usually found from C:\Program Files\Solibri\SOLIBRI\log
        • EgilsBE Offline
          EgilsBE Offline
          EgilsB
          @lasse-lindqvist, many thanks, logs will come through soon.
          • BramB Offline
            BramB Offline
            Bram
            One customer have the same issue - I can replicate if choosing Anywhere and go into settings, nothing happens when clicking “Add Server…”, back in Office it works fine.
            Case sent to Support
              replied to Bram on last edited by
              Adding a server needs network connection to Solibri servers to retrieve the list of the BCF Servers.
              It is possible that this is a networking problem. Lets see the logs.
                rahul.sule
                wrote on last edited by rahul.sule
                We looked into the logs from another instance but similar case and found that:
                • Anywhere starts in case of SSC connection errors
                • BCF Server cannot be retrieved from SSC in case of such a connection error
                • The connection error is HTTP 401 Unauthorized
                It would be good to:
                • Test signing in to solution.solibri.com, to make sure there are no issues with the credentials
                If that is successful, then:
                • Try removing the “.solibri” folder (located at C:\Users<user name>) and sign in again
                Please try these out and let us know how it goes.
