  3. Is it possible to use the rule 231/1.6 with a condition for the checked component?
3 Posts 2 Posters 611 Views
    Anees Alomar
    e.g. I want to check all the rooms “which are closed with only window openings” if they have a door,
      replied to Anees Alomar on last edited by
      @Anees-Alomar said in Is it possible to use the rule 231/1.6 with a condition for the checked component?:
      I dont’ understand this clear enough. Could you describe more detail what is the problem that the rule would solve / check?
        Anees Alomar
        Hi Matti, thanks for your reply, I use this rule to check if each room has a door, but we have many rooms as open space and don’t have doors. So my question was: is it possible to check “only rooms that are closed with at least 4 walls”?
