  3. Objects should not to be in the model
3 Posts 3 Posters 700 Views
  • G Offline
    G Offline
    GTS
    I want to create rule which can find objects which should not to be in the model, but I can’t find the way to do that.
    Maybe anyone can help with this?
      You would need to elaborate this a bit more.
      What are you looking for? Elements on specific Layers, with spefic Names or for elements which are located anywhere specific?
      In general I would start with a classification where you collect all “Not allowed elements” and then use SOL 230 with the requirement that all elements in the model must not have this classification which brands them as an unwanted outsider.
        @jsn said in Objects should not to be in the model:
        use SOL 230
        In some cases the rule #230 can be used without classifications.
        This example shows checking of invalid spaces:
