  3. is there a rule that checks the dimension between the top edge of the ProvisionForVoid and the lower edge of the slab above the PFV elements? in a way that the
5 Posts 3 Posters 1.0k Views
    Anees Alomar
    Hi Everyone,
    I am looking for a rule that checks the dimension between the top edge of the ProvisionForVoid and the lower edge of the slab above the PFV elements, in a way that checks that all dimensions are clear numbers, like 20 cm, 25 cm, 30 cm. Not 37 cm or 43 m.
    chrisC 1 Reply Last reply
    • Maxime SabbaghM Offline
      Maxime Sabbagh
      The “component distance” Rule is the one I use
      https://www.parallel.digital/
      A 1 Reply Last reply
        replied to Anees Alomar on last edited by
        @anees-alomar Good luck with this Issue. I never saw MEP planner who can handle this properly 😉
        But i also use the distance rule 222 for that.
          Anees Alomar
          replied to Maxime Sabbagh on last edited by
          @maxime-sabbagh thank you, the distance rule has a minimum and a maximum range, but it doesn’t check if the number is clear or not. Thanks anyway
            Anees Alomar
            @chris well, the MEP planners are doing great job with us, however it is better to develop a rule so we can have the PFVs controlled, but you are right, it is very hard to find someone who can do it right.
            The 222 rule will check if the PFVs are into the min. or max distance from the slab, but it will not check how many numbers there are after the comma. Thank you 🙂
