  4. Automating IfcOptimizer ... Did you know?
ifcoptimizer
4 Posts 4 Posters 1.6k Views
  • cpreidelC Offline
    cpreidelC Offline
    cpreidel
    wrote on last edited by cpreidel
    Hey all!
    Recently I have been talking to customers about the IFC Optimizer, and some asked if it is possible to automate the Optimizer a bit.
    Answer: Yes, you can! The application can be executed via console commands so that you can easily create a batch file (on Windows). Just try something like this
    for %%f in (*.ifc) do (
    	"c:\Program Files\Solibri\IFCOptimizer\Solibri IFC Optimizer.exe" -in="%cd%\%%f" -out="%cd%"
    To make life easier, just extract StackOptimizer.bat from StackOptimizer.zip into the folder with your IFCs and execute. Additionally, I added a Readme.txt file, which contains a bit more information on how to use the console commands.
    Have fun!
    R 1 Reply Last reply
    6
    • Daniel D.D Offline
      Daniel D.D Offline
      Daniel D.
      Hi everybody,
      the StackOptimizer Cornelius shared with us is great and works perfectly on a local drive. Unfortunately it did not work in a folder on our server.
      During the Solibri Society Event in Barcelona, Ibrahim Beqiri helped me out and changed the .bat-filein a way it does work when executed from a network-folder.
      You just have to fill in the correct folder path in the bat-file. NetworkStackOptimizer.zip
      The very smart thing about the original file is, that you could execute it from any (local) folder just like it is. When using the NetworkStackOptimizer you have to change the folder path to the actual folder where the ifc-files are.
      It would be nice if anyone could improve the file in a way that it works from a networkfolder without having to adjust the folder path, Just optimizing the ifc-files in the folder where the bat-file is executed from.
      Good luck,
      Best regards, Daniel
      • F Offline
        F Offline
        fwicki
        wrote on last edited by fwicki
        @cpreidel said in Automating IfcOptimizer ... Did you know?:
        %%f
        Hey there,
        Old thread, I know, but is there any way to achieve this on osx? like with automator, javascript or python?
        glad for any hints, tipps (;
        thanks a lot and best
          Ronald van Emst
          replied to cpreidel on last edited by
          Hey all!
          Have fun!
          Then i have another question about this thread as well.
          Is it possible to run this feature in the same batch file as the Autorun batch file? So we can first optimize the files and in the same action they will update these files into the .smc file.
          thanks.
