  3. Issues duplicated with BCF Live and BIMcollab
39 Posts 16 Posters 20.3k Views
    Dennis
    replied to riina on last edited by
    @riina is there any information regarding the problems in the BCFConnector? The upgrade to 9.12.5 was not the remedy.
    Dennis Beeke
      replied to Dennis on last edited by
      @debeek said in Solibri 9.12.5 has been released:
      Dennis Beeke
      Hello @DeBeek,
      Could you be more specific? Which problems are you referring to?
      T D 2 Replies Last reply
        Trina
        @tonigyllenberg
        I just sent an email to Siolibri Support reagrding the BCF Live connector issue
          Dennis
          Hello @tonigyllenberg , several users do have problems with the Live connector and synchronization to BIMcollab.
          We did have contact with Kubus and they told us that there is a bug in the BCF Live Connector, which causes these problems:
          • issues are uploaded multiple times to BIMcollab. (hundreds of times)
          • edit dates and editors are overwritten at the BIMcoillab platform.BIMcollab - edits issues worden overschreven.jpg
          Dennis Beeke
          chrisC 1 Reply Last reply
            replied to Dennis on last edited by chris
            @debeek said in Issues duplicated with BCF Live and BIMcollab:
            Dennis Beeke
            I had the same issues at the beginning. Be very careful with sync. I always sync manually. Go under solibri settings and disable the automatic sync. During sync process do not change anything on the issues. After the sync always save the modell. Disable the sync tab on bcf live. Afterwards enable the sync button.
            And maybe it is best, when you define timeframes where every discipline is allowed to sync issues…
            Best
            Chris
            D 1 Reply Last reply
              Dennis
              Thanks @chris, the manually sync is the way we always do.
              Regards,
              Dennis
                Regards,
                Dennis
                Had the same issue than you, when i changed something during the sync process… Maybe this also occur when to much people sync at the same time.
                At the beginning i was really unhappy with the BCF live. But now, it works really well 😉
                  Mvandenbrink
                  These issues with duplicated items also happen when automatic sync is turned off. Happend to us a few times since the beginning of BCF Live Connector. These issues also messes up the statistics of BIMcollab because you are unable to delete these duplicated items.
                    replied to Mvandenbrink on last edited by
                    @mvandenbrink said in Issues duplicated with BCF Live and BIMcollab:
                    i could delete this issues…
                    M 1 Reply Last reply
                      Mvandenbrink
                      @chris said in Issues duplicated with BCF Live and BIMcollab:
                      Could you describe how you got the duplicate items/issues deleted? We contacted Kubus but they told us it wasn’t possible at this moment.
                        That would be indeed interestingto hear!
                          @jsn said in Issues duplicated with BCF Live and BIMcollab:
                          Okay you are right. i closed the issue and not deleted it. Sorry… And of course it affect the statistic.
                          With the steps i described, i didn’t have this issue for 4 month now. before this time i had two times the issue with duplicate ones…
                            Remco
                            wrote on last edited by Remco
                            Any news @Solibrians regarding these problems? Adding multiple (empty) issues is annoying, but overwriting the complete history of several issues in the BIMcollab database as @Dennis described is unacceptable. Do we have to roll back to an earlier version of Solibri 9.12 or will there be a hotfix for this in the very near future? Currently I advised my colleagues not to use BIMcollab in combination with BCF Live Connector in either Solbri 9.12.4 or 9.12.5 because I don’t want to risk overwriting more issues. Please respond Solibri!
                            • david.weltsD Offline
                              david.welts
                              Hello everyone and thank you for the feedback.
                              We are currently looking into the issue. The more information we get, the easier it is for us to identify the problem.
                              @Remco could you please describe your process in detail, step by step? Can it be easily reproduced with a fresh project and sample file, or does this problem always come about with the same procedure (or same model)?
                              Another thing which comes to mind, there are known problems with issue duplication when combining BCF Live Connector and the previous BCF Connector. This also means, that everyone working on the project should be using the BCF Live connector to avoid this problem. There are some more tips and information available here.
                                Remco
                                Hi @david.polanski, and by all means, please read along @Solibrians:
                                Me and several colleagues experienced different problems with synchronization of issues from Solbri to BIMcollab in the last two months or so. We all use Solibri 9.12.X and therefore, as far as we can tell, the use of the previous BCF Connector is not what is causing these issues. I will try to describe the process as best as I can:
                                Problem #1: One issue ended up in BIMcollab 40 time with no picture.
                                This first error occured the 22nd of February.
                                What happened:
                                I created several issues using checking rules, which I stored in a local presentation.
                                After correcting and adding Labels etc. I then imported these issues in the BCF Live View.
                                Note: the checkbox in the Solibri BCF Live Connector settings (Use automatic synchronization) is always unchecked.
                                Halfway through synchronization I noticed the progress indicator at the bottom of the screen got stuck. In the BCF Live View I saw one issue was not able to sync. After waiting for more than 5 minutes, I closed the BCF Live connection. When I reconnected the BCF Live connection, the remaining issues synchronized without problems, but then I saw the one issue got replicated 40 time, with no picture.
                                (This problem was reported to BIMcollab under #6779. As requested by BIMcollab I submitted Solibri logs on the 1st of March which were forwarded to Solibri )
                                Used Solibri Office Version: 9.12.3.16
                                Problem #2: Several hundred (+/- 400) copies of one issue with no picture
                                This error occured the 22nd of March.
                                What happened:
                                This time the issues were created in the new (not based on checking results) and when my colleague tried to synchronize issues, one issue was created about 400 times. (similar to the first image in post of @Dennis)
                                (This problem was reported to BIMcollab as a follow up on #6779. As requested by BIMcollab my colleague submitted Solibri logs on the 25th of March which were forwarded to Solibri )
                                Used Solibri Office Version: 9.12.4.18
                                Note: the checkbox in the Solibri BCF Live Connector settings (Use automatic synchronization) is unchecked.
                                Problem #3: Edit dates and editor names are overwritten at the BIMcoillab platform
                                Different colleague, different problem. He was is a meeting, where he was presenting and discussing several issues, using the Live Issues in BIMcollab from Solibri.
                                After an hour he received a warning (BCF Live Connection Paused) after which he reconnected.
                                However, after the two hour meeting, he noticed in the BIMcollab website that several issue were overwritten. All dates in the issues history were changed to the 13th of April, all names in the history of the issues were changed to his name. (See screenshot in the post of @Dennis)
                                Needless to say that the unsolicited alteration of issue data is killing for our process. This is already causing problems for us, because we have a discussion with a subcontractor about issues that are open for too long: we currently don’t have any valid proof any more of when these issues were initially activated, when we received a response, by whom and so on)
                                Problem #4: Several hundred (+/- 1300) copies of one issue with no picture
                                The same situation as described under Problem #2 happened to the same colleague yesterday.
                                What happened? After his working day, he closed his laptop (around 5 P.M.) Meanwhile Solibri was still running, and apparently still synchronizing issues. This process stopped when he finally switched of his laptop around 11 P.M. During this period around 1300 issue (all the same, with no picture)
                                (logs not yet secured)
                                I know, it’s obviously not the smartest thing to leave Solibri running, especially not with an active sync, but I think the system should be smart enough to prevent this from happening in the first place.)
                                Problem #5: 14 copies of one issue with no picture
                                The same colleague (the one from #2 and #4) again had problems synchronizing. Locally created issues were imported in the BCF Live View and after pressing Mark As Ready some issues were indeed sent to BIMcollab, however this process got stuck again halfway.
                                He cut the BCF Live connection, to find out ‘only’ 14 issues were created.
                                (Difference between #4 and #5 was that in cases #2 and #4 he was working from home (WiFi connection), and in #5 he was connected to our company LAN.)
                                The above mentioned problem all occurred in the same BIMcollab domain, from within the same company domain (either directly from our company’s LAN or through VPN)
                                We have so far not been able to reproduce these issues on demand / at will. Luckily this does not occur every time we synchronize issues, and not with every colleague, but as I stated in my earlier post this has to be fixed, espcially Problem #3 needs to be addressed and fixed with the highest priority, because this is really unacceptable.
                                Hope to hear a permanent solution from you soon!
                                degraanD 1 Reply Last reply
                                • degraanD Offline
                                  degraanD Offline
                                  degraan
                                  replied to Remco on last edited by
                                  Hi Remco and other Solibrian,
                                  We (BIMcollab) are looking into this topic together with Solibri.
                                  For now we know that using "http” instead of “https” in the address you connect to, is not managed well and can cause problems.
                                  Please use https in URL’s used for connecting from Solibri to BIMcollab.
                                  We keep you posted.
                                  Regards,
                                  Ronald
                                  R 1 Reply Last reply
                                    Remco
                                    replied to degraan on last edited by
                                    #18
                                    Hi @degraan , thanks for your response and your suggestion. I’ve (double)checked my settings and also the settings of the colleagues who experienced the problems as described above, but as far as I can tell, everyone uses ‘https’, as instructed. So the problem is probably caused by something else.
                                    • Y Offline
                                      Y Offline
                                      YasmineD
                                      Me and my colleagues also use the https option and still had the same issue. So probably not what is causing it.
                                      • degraanD Offline
                                        degraanD Offline
                                        degraan
                                        replied to YasmineD on last edited by
                                        @yasmined Thank you for your addition. Can you indicate which issue is still in question, copies of issues or data modification?
                                        Y 1 Reply Last reply
                                          Mvandenbrink
                                          Hi @degraan Me and my colleagues also use the https option and having issues with duplicated items. Multiple items duplicated multiple times including comments, viewpoints etc. No data modification.
