  3. Where are the Presentation Prefixes?
5 Posts 2 Posters 1.1k Views
  • _c__ Offline
    _c__ Offline
    _c_
    I don’t understand how to use the Presentation Prefix. I can set it up, but then I see it nowhere. The help states:
    If you wish, give the presentation a prefix. Prefix of a presentation is used to differentiate issues between presentations. It can be any alphanumeric string; the system automatically appends a unique number to issues in the presentation.**
    Where is this visible? What is it meant with “Differentiate issues between presentations”?
    … still trying to figure out how to organize issues in a large project.
    c
      replied to _c_ on last edited by
      @_c_ said in Where are the Presentation Prefixes?:
      I hope the pictures will help. There will be autogenerated tracking ID which can be different in each presentation.
      • _c__ Offline
        _c__ Offline
        _c_
        Thank you so much for your fast answer, it is really great the kind of support you developer are giving here.
        A thing that I noticed, is that using prefixes in the presentations allows me to create duplicates of the issues that keep the triangle (link to the rules/model).
        If we only use copy-paste, the link obviously is lost.
        The tracking ID is always and forever incremental, isn’t it? Is not overwritten upon re-running rules?
        The prefix could then be used to create multiple presentations. Very indirect, but somehow a possibility.
        Matti, do you have somewhere a list of the events leading to un-linking of issues?
        c
          • Tracking ID = PREFIX + NUMBER.
          • Tracking ID is not overwritten.
          • The NUMBER is unique in the model, incremental, starting from 1.
          • NOTE: Tracking ID is not in BCF standard
          • The same prefix can be used for multiple presentations.
          • Can be changed later.
          At least in these two cases:
          • When ruleset is removed.
          • When the checking result is no more present (issue fixed or parameters of the rule are changed).
          • _c__ Offline
            _c__ Offline
            _c_
            Thank you
            c
