  3. Export Classification in Ifc
16 Posts 6 Posters 5.6k Views
    Michael Enste
    Looks quite helpful and would be a great benefit. Unfortunatelly the file isn’t available at we-transfer anymore. Can anyone share it once again? Thanks.
      BIM1337
      replied to BIM1337 on last edited by BIM1337
      @bim1337 said in Export Classification in Ifc:
      @jeroenkoomen said in Export Classification in Ifc:
      Do you mean this?
      https://www.linkedin.com/posts/daanarts_ifc-ifc-ugcPost-6879092239402967040-Pujb
      Just increase the window size worked for me.
      It shows up for me after selecting a Source IFC.
        BIM1337
        replied to paola bronzo on last edited by BIM1337
        @m-enste said in Export Classification in Ifc:
        Classification in IFC.zip
        M 1 Reply Last reply
          @paola-bronzo
          Ik also tried it today but have the same problem…
          List of classifications does not show up…
          stretching the window tot full screen size does not help.
          not able to get this working…
          would be nice feature for Solibri to implement… can not be that difficult if it is possible to put it in a .jar file of 16kB
            Michael Enste
            @bim1337 Thanks for sharing.
              So far the plugin is a bit bugy but it worked with simple models very well. With larger models i couldn’t export the ifc (error). I assume, that the problem occur with complex geometries.
              @Solibrians Why not implement this functionality in Solibri as default? Export classification in Property Sets and IfcClassification Reference would be great.
                BIM1337
                wrote on last edited by BIM1337
                Credits to Daan Arts of course for sharing this on Linkedin, but no problem!
                @chris said in Export Classification in Ifc:
                Indeed to have this in Solibri would be great, although the plugin works fine.
                I’ve exported on a decent Architectural IFC model that’s around 170mb, it worked but at first I thought it was freezing. The Solibri screen will remain frozen, for this model it was aprox 2.5 hours. But after that it completed the export, so large models will take quite a long time! But it does work, it doesn’t freeze without doing anything.
                So after 2.5 hours Solibri will unfreeze and it’ll say export succesful.
                chrisC 1 Reply Last reply
                  @bim1337 I recognize that with frozen screen too. But i get an error message during re-import the IFC. File is damaged…
                  B 1 Reply Last reply
                    BIM1337
                    Hmmm, for me it worked on multiple IFC files, created in Revit ifc2x3.
                    Maybe it’s the ifc version?
                      @bim1337 Ifc Files with complex geometries. CurtainWalls? Pipes? Profiles?
                        Idea to run the IFC through the IFC optimizer first?
                        Another program that I use is Simplebim, for re-exporting an IFC. This helps sometimes with buggy IFC models…
